Car won't start please help
Old Jul 12, 2009 | 06:00 PM
turbostud2's Avatar
I have a 96 Trans Am. I swapped out the opti now the car just turns over and won't start. It doesn't feel like it's catching and trying to start. I did the screwdriver test and got spark out of the wire to the plug. I double checked all my wiring harness'. I smell fuel, and even tried a little starting fluid still nothing. I took a few plugs out and there smelt like fuel. Any info or ideas on what you might think it is would be great!! Thanks -Kyle-
Old Jul 12, 2009 | 06:24 PM
Robs97Z28's Avatar
you made sure to put the opti on the correct way. lining up the cam dowel pin to the correct location on the opti drive shaft?
http://shbox.com/1/opti_back.jpg
Old Jul 12, 2009 | 07:10 PM
turbostud2's Avatar
I'm 99% sure I put it in the correct slot. Is it possible to put the dowl pen in the wrong slot without forcing it on? Thanks for the suggestion anymore?
Old Jul 12, 2009 | 10:30 PM
Robs97Z28's Avatar
yes, I used to hear it a lot on the form. The link show you were the dowel must go. there are 3 slots it can fit into, but only 1 is correct.
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
