Car wont start,new Opti,Waterpump,starter,coil,wires! STILL NO START PLEASE HELP!!!!!
Old May 20, 2006 | 02:18 PM
CJ Black LS1 Z28 M6's Avatar
Ok people I replaced the Opti,waterpump,coil,starter,battery and a few other things and the car still wont start! I hear the fuel pump engage when i turn the key. I checked that main ground on the front of the block also. I dont think its the fuel pump, also I dont think its the igntition switch because i have owned other Lt1 cars in the past where it went bad and when i turned the key i didnt get a click or anything.
When I turn the key the 1st couple of times the car will sound like it wants to crank over but it doesnt. Then after a couple more tries it just starts to click. Im really so pissed right now. I took alot of time after work and a weekend putting the car back togther and now more problems
Any help would be appreciated i did a search and tried alot of things but nothing i tried worked.
Old May 20, 2006 | 04:03 PM
MEAN LT1's Avatar
Re: Car wont start,new Opti,Waterpump,starter,coil,wires! STILL NO START PLEASE HELP!!!!!
You try the icm yet?
Old May 20, 2006 | 04:22 PM
firetird's Avatar
sounds like a dead battery???
Old May 20, 2006 | 06:36 PM
94zrag's Avatar
Usually when it just clicks, its a bad ground(from my experience anyway). Have you replaced the main ground wire that hooks to the battery? I had to replace mine last year, I would just turn the key and the car would either click rapidly or just not do anything. The ground didn't look bad from the outside, but when I opened it up it was all coroded.
Old May 21, 2006 | 01:46 AM
kennyrebbe's Avatar
does your car dash lights dim down when you start? I've had this problem and I thought it was the battery, but it ended up being the positive terminal block in front. Its the connections right in the red cap. Tork it down with a ratchet, and possibly take it apart and clean all the connections. I did this and mine started right up. Yours could be a different case, but its worth a try.
thenewkid
Nov 27, 2014 09:41 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
