car won't start
Old Dec 23, 2006 | 02:32 PM
red94chicken's Avatar
car won't start
ok.. so i let my 94 hotcammed t/a sit for a few weeks.. went to start it.. and it didn't fire right up.. so i jumped it and it puffed out some white smoke and shot a bunch of water out the exhaust.. i was like **** maybe it just puked a gasket. so i checked the oil.. it was kinda milky. so i changed the oil. fired it back up and it ran fine.. then it stalled and was really hard starting.. but it would run just not right..so i swapped the stock untuned computer out for one that has a tune on it.. still runs like crap. so i swap the tranny which was the reason i left it sit.. it takes 10 minutes to get it to start and 15 to actually get it out of the garage.. then the next day it wouldn't start at all.. changed the icm.. no change.. changed the cap and rotor.. still nothing.. changed the opti... backfires here and there. still won't run.. swapped the coil.. still not running.. pulled the valve covers to see if a rocker backed off but they are all tight and actuating the valves as they should. then i was wondering if it were a fuel problem.. so i hot wired my fuel soleniod to see if it had fuel pressure and it does.. the gas smells kinda funny though.. i can't get it to run so i can't get any codes... don't know what else i should look at or check. oil hasn't turned milky again since i changed it.. what do i do..
Old Dec 23, 2006 | 02:42 PM
aboatguy's Avatar
If I found milky oil:
I'd check the plugs and do a compression test and a leak down when the plugs were out.
Mike
Old Dec 23, 2006 | 04:22 PM
well i live in new york and it has been very wet and like i said it had been sitting a while and i did run the car after i changed the oil long enough to be able to notice if it were still leaking coolant into the engine..not to mention that it didn't lose any coolant at all and it has zero moisture in the oil since and its been left in a climate controlled garage.
Old Dec 23, 2006 | 05:45 PM
aboatguy's Avatar
I was just going by what you wrote:
... then it stalled and was really hard starting.. but it would run just not right...
You did a lot of trouble shooting that is much harder to do than compression and leak down tests and I would have checked the plugs before changing the opti/cap/wires etc.
Old Dec 23, 2006 | 09:32 PM
they are brand new.. engine only has 200 miles if that on it.. i just used a extra vented opti that i had kicking around from my vette when i put the engine together.. i had a spare 95 timing cover also so i just upgraded it... so that is why went for the opti first... and it had an original icm with 155,000 miles on it so i thought why not..and i had bought a new coil when i built the motor.. the wires were new too...
Old Dec 25, 2006 | 12:45 AM
solarofthesix
Guest
Posts: n/a
this might sound stupid....but did you replace the cam dowel pin? If you did the venter swap, you need to have a longer dowel placed in for the car to start.
Old Dec 25, 2006 | 02:44 AM
yes the hotcam that i put in the new engine has a long dowel. and it had been running fine for sometime till the tranny took a dump and i parked it till i had the new one which i then used the car to take it to the garage so i could change the tranny and ran into my current situation..
Old Dec 26, 2006 | 03:16 PM
anyone??
Old Dec 29, 2006 | 08:45 PM
Guest47904's Avatar
Guest
When you had a problem with the tranny that promted the overhaul, did that problem occur very quickly and did it shut the engine off?
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
