car wont start
Old Nov 6, 2005 | 11:26 AM
jadams94ta's Avatar
car wont start
it wont crank over at all . i check the purple wire going to the starter and it dont get any volts at all . all the gauges work fine . it will start if i start the and mess with the key by turn it back and forward . when it does start my sec. light comes on . any help would be great
thank guys
jason
Old Nov 6, 2005 | 12:55 PM
OBE1 95Z28's Avatar
Re: car wont start
Sounds like the VATS system is failing. Do a search on VATS, the contacts that touch your security pellet of your key way be worn any not making proper contact.
Old Nov 6, 2005 | 07:11 PM
jadams94ta's Avatar
Re: car wont start
well it not the vats . i just had my tuner stop by and turn the vats off and other ideas
Old Nov 7, 2005 | 05:09 AM
Guest47904's Avatar
Guest
Re: car wont start
Sounds more like an ignition switch problem. Elminate all the other possibilities first. Since he supposedly removed the vats, put a jumper from pin 86 of the theft deterrent relay(TDR) to ground. This will allow the theft deterrent relay to function with the tranny switch to protect you from starting it in gear. If it still does not crank, turn the key to crank position and check for voltage on pin 85 and 30 of the TDR. If there, bench test the relay or pull another to put in its place. If not there, probe the yellow wire on C200 coming from the steering column.
C200 is the large 48 pin connector located just left of the steering column. And check the connector for the purple wire on C210 which is a black 4 way connector behind the RH kick panel.
Old Nov 7, 2005 | 05:12 PM
jadams94ta's Avatar
Re: car wont start
im getting 12volts to the tdr and i was reading about using a jump and i tryed that and nothing
Old Nov 8, 2005 | 05:30 AM
Guest47904's Avatar
Guest
Re: car wont start
If you are getting 12 to pin 30 but not through the purple wire even with a jumper from pin 30 to pin 87, than the problem is the purple wire. Ohm the purple wire from the relay socket to C210 and then if need be, from C210 to the starter.
Old Nov 10, 2005 | 10:15 PM
jadams94ta's Avatar
Re: car wont start
well i replaced the purple wire and still nothing .i when under the car to day and jumped the starter to make sure it was it
Old Nov 11, 2005 | 05:13 AM
Guest47904's Avatar
Guest
Re: car wont start
Back up and start over. Is voltage at pin 30? Does the relay make contact between pin 30 and pin 87 when power and ground are applied to pin 85 and 86? Is there continuity from the relay socket to C210? Is there continuity from C210 to the starter?
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
