Car Wont Start!
Car Wont Start!
Here's the story, my car (94' Z M6) has been sitting for 6 months, and today I drove it for about 30 miles and it died on me (I filled the fuel tank before I drove it). When I was driving it and accelerating, it hesitated. Any suggestions? Also, what are some ways I can tell if the fuel pump is still good besides turning the key to "On"?
I tried to push on the schrader valve and see if I got fuel out of it when the key was in the "On" position, and not a drop of fuel came out. Is the fuel pump gone? Also, how do I check if the ignition coil is good?
If you didnt get any fuel out it is not a good sign at all. Your pump should pump up the pressure in the line when you turn the key forward. If this was working properly you would get some fuel spray from the valve when you pressed it. You could also get a fuel test gauge that screws on the shrader valve and see if your getting any pressure at all.
