car won't start; possible fuel pump problem?
Old Jul 16, 2003 | 02:31 PM
Adam Lengerich's Avatar
the other day my car ran out of gas and now it wont start back up. When i turn the key on now, I don't hear the pump come on! I've jumpered the prime wire under the hood and it still doesn't come on. I have my Haynes manual and it says to check the fuel pump fuse in the fuse box on the side of the dash; but there is no fuse that says it's for the fuel pump! Am I just illiterate or is it not there? Please help! I'm getting ready to start punching myself in the nuts soon!
Old Jul 16, 2003 | 02:47 PM
TedH's Avatar
There should be a fuel pump relay under the left footrest area in the interior. That can keep a fuel pump from turning on. Much easier to replace than the pump too.
Old Jul 16, 2003 | 04:25 PM
If there is nothing wrong with the wiring to the pump, jumping the prime connector wire bypasses the relay (only on pre-96). You might want to prove that the wiring is good by checking it at the connector under the car by the fuel filter. Make sure power is getting there on the grey wire when the key is first turned ON or the connector is jumpered. Also check the ground wire.
Old Aug 7, 2003 | 11:42 PM
Teal94Z's Avatar
Those are some nice wheels you have on your T/A
Old Aug 7, 2003 | 11:50 PM
Wild1's Avatar
When you say "don't start" do you mean "no crank" or "no start"? The reason is that make sure it is a fuel concern by squirting a short burst of starter fluid in the intake... if it runs for a sec, then you confirmed it is a fuel issue. Yes, you should hear a fuel priming pulse at Key On. But you may have multiple concerns...
pologreen97z
Dec 2, 2014 10:42 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
