Car won't run with check engine light off
Old Apr 10, 2005 | 11:29 AM
white91z28's Avatar
Exclamation Car won't run with check engine light off
I have a 94 lt1 and for some reason my car won't run with the car out of safe mode. I have replaced the opti spark and coil no help. The only way it will run is with the MAF disconneted. And yes I have replaced that too and no help. What could be the problem. PLEASE HELP
Old Apr 11, 2005 | 05:35 AM
slopokrodrigez's Avatar
Re: Car won't run with check engine light off
On a 94, the same power line bringing 12 volts to the MAF, also carrys 12 volts to the PCM, the theft detterent module and the fuel pump relay. On each one of those devices, it's the pink wire. If anyone of those has a problem where it's pulling the 12 volt line down, it will effect the other devices on the same 12 volt line.
Measure from the pink wire to ground at the MAF connector with the MAF unplugged and with it plugged in with a multi-meter.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Jul 4, 2005 05:00 PM
