car won't rev past 6k
Old May 28, 2006 | 10:22 AM
93LT1355's Avatar
had my car dynoed the other day and we noticed that the car wouldn't pull past 6k rpm. I just starts to miss out kind of like its hitting a rev limiter. I'm almost positive its not hitting a rev limiter and I'm leaning towards it being a opti problem. Tell me what you guys think. thanks
Old May 28, 2006 | 12:03 PM
96WS6TA's Avatar
Re: car won't rev past 6k
Maybe valve float??
Old May 28, 2006 | 12:14 PM
93LT1355's Avatar
i'm pretty sure i'm good on valve springs so i hope there is no valve float
Old May 28, 2006 | 12:26 PM
93LT1355's Avatar
well i have a pcmforless chip and he should have changed the rev limiter along with his tune. I've sent him a message to check and be sure.
Old May 28, 2006 | 01:14 PM
Chopstix's Avatar
check your MAF calibrations...and your ignition...plugs, wires, coil, etc
I experienced the same thing....burnt plug wire
Old May 28, 2006 | 01:42 PM
thesoundandthefury's Avatar
Stock untouched heads typically run out of air around 6K. Didn't see any mention of head mods in your sig so that's what I'm leaning towards.
Old May 28, 2006 | 02:06 PM
Hot94Z28's Avatar
I say its the rev limiter you might cheak with pcmforless but does your set up need to go that high
Old May 28, 2006 | 02:08 PM
Hot94Z28's Avatar
I just seen you have a dig 6 box whats it set at
Old May 28, 2006 | 04:15 PM
1racerdude's Avatar
Fuel table runs out at 7200 and the rev limiter should be tuned to what ya want it set at,in the computer.
Old May 28, 2006 | 04:36 PM
93LT1355's Avatar
my car is speed density so i have no maf and all the plugs and wires look good.
The digital 6 box is set at 6300. i'm going to make sure with pcmforless about the limiter.
Garcia5
Jul 7, 2022 06:51 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
tds1213
Nov 27, 2014 12:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
