car will not start
Old Jan 19, 2006 | 11:13 PM
camaro1fastz28's Avatar
car will not start
had not run my 1996 camaro in one week start it today drove it out of the garage left it outside warm up like 15 min it cold here in jersey so i went to take off and it stalled and will not start if it does it run like **** but barely run i hear the the fuel pum run. changed plug and wire cupple of week ago motor has 58,000 on it. it had msd 6al unpluged it taght it might have been that but it was no same sysmothm need help
Old Jan 19, 2006 | 11:15 PM
87bandit's Avatar
Re: car will not start
alt, bad battery, opti, or vacuum leak maybe?
Old Jan 19, 2006 | 11:50 PM
How about.... car was cold, you pulled it outside into humid air, and a lot of water condensed on the plug wires, coil, ICM and Optispark?????
Old Jan 20, 2006 | 12:19 AM
87bandit's Avatar
sounds good to me
Old Jan 20, 2006 | 09:03 AM
it not the alt or bat cause it crank fast with compression i am thining it the opti it was not humid out it was cold in the garage and cold outside opti has 158,000 mabe it went?
Old Jan 20, 2006 | 09:54 AM
thehunter's Avatar
All the starting problems I ever had with my 94 Z28 was a result of bad coils. It would crank all day long, just wouldn't start. Replaced it 3 times, 1 MSD and 2 stockers.
Mike
Old Jan 20, 2006 | 03:23 PM
Angry Re: car will not start
i checked the coil got spark out of coil but none at plug thing ompi can this be it
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
blac94Z
Dec 2, 2014 12:09 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
