car will die then turn back on
Old Mar 12, 2011 | 08:23 AM
summers_Z28's Avatar
Generally happens when i'm driving.. but atleast everyday when i start driving my car will cut off for maybe 1 second then turn back on..generally i let off the gas pedal then lightly hit step on the pedal..
I didn't drive the car alot in the winter due to a bad transmission and didn't start it up unless i drove it. I'm thinking there may be water build up in the tank so i've been using items like Heet and one lucas oil product..cant remember the name. I'm just pretty much wondering if this is water, what is the easiest way to get it out of the tank?
Old Mar 12, 2011 | 02:46 PM
Re: car will die then turn back on
Have you scanned it for codes? If the PCM loses the Opti cam position sensor low res pulse, it shuts down the fuel system. May be an intermittent problem or a corroded or damaged Opti harness connector. Look for DTC 16 - does not turn on the SES light.
Or could be an intermittent problem with the ignition switch. Shoebox has a troubleshooting page:
http://shbox.com/ignsw/ign_switch_repl.html
Old Mar 12, 2011 | 04:34 PM
where could i buy a scanner from? one thats good but doesn't shoot me in the pocket
Old Mar 13, 2011 | 09:11 AM
You can get free scan software, then buy a cable to hook up a laptop:
http://www.ttspowersystems.com/DataMaster.html
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
http://www.akmcables.com/
Or find a used Auto Xray OBD-I scanner (not a cheapie that shorts the pins - won't work on a 94 or newer).
bfmv13trivium
Jan 14, 2015 09:57 AM
NewsBot
Dec 3, 2014 12:30 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
BigED
Jul 26, 2002 09:22 AM
