car trouble!! help!!
Old Nov 23, 2005 | 05:15 PM
fade2blk500's Avatar
Okay so the car died about a month back and wouldn't crank back. I replaced the opti with a brand new one from jason cromer. I noticed that the opti harness was corroded, but didnt have the money at the time to replace it. Bolted in the new opti and everything.. car fired rightup. 3 days later it stalled out and wouldn't crank back. I figured it had to be that bad harness so i purchased a new harness from gm for 150 bucks. Car fired up perfect. Drove it 10 miles, car stalled out again and now continues not to crank back. I am lost as to what it could be.
Craig
Old Nov 24, 2005 | 09:45 PM
Re: car trouble!! help!!
nobody??
Old Nov 24, 2005 | 09:50 PM
flatlander757's Avatar
First check battery voltage and all electrical connections, see if the starter is getting enough power, see if the alternator is working properly, make sure no squirrels are in your number 5 cylinder...
Old Nov 25, 2005 | 11:04 AM
Gripenfelter's Avatar
Did you get coolant on the new opti when you re-installed the waterpump?
Otherwise check your coil wire and coil.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
slothgrant
Aug 22, 2002 03:01 PM
squirrels
Jul 13, 2002 01:58 AM
