Car surges under light throttle
Old Mar 21, 2003 | 05:59 PM
scott95ta's Avatar
If the car is under light throttle and a moderate load, say going up a slight hill, and in OD I will get a surge like the TC cannot make up it's mind.
I had installed new O2's and made some programming changes while I fixed the intake oil leak. On my first few test drives the car was great. The programming changes I made were idle, fan temps, removed knock retard and I increased the MAF tables by 10%(due to ported MAF). I stopped to get gas this morning and noticed that I had not retightened the gas cap from releasing the pressure in the tank. Never set the SES light either.
Now that I have gotten gas and tightened the gas cap to three clicks I am now getting the surge again.
WHY??
I though the system has to be capped on the filler end to work correctly. I am going out in a bit to grab a bite, I am going to loosen the gas cap so that it just stays on and see what happens.
Anyone with an explanation for this?
Old Mar 21, 2003 | 06:38 PM
94bonefast's Avatar
My car did that once. I kept loosening off the cap and driving, tightening , driving , eventually it went away. Hoping so eh?
Old Mar 21, 2003 | 06:57 PM
scott95ta's Avatar
Test drive complete -- NO SURGE
Ok I give up, do I have bad cap? Is the fuel pump getting weak? I guess I need to do run with the fuel pressure guage, the cap on tight and see what happens.
Anybody have any suggestions?
Noenav
Mar 1, 2019 07:38 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
