Car Still Wont Fire HELP!!
Old Apr 24, 2004 | 12:57 AM
c0rey's Avatar
Exclamation Car Still Wont Fire HELP!!
Hey whats up one nite my car just died on me and wouldnt start up again. Here is what I have checked so far!!!!
Compression Test-Good
Fuel Pressure Test-Perfect
Brand New Opti-Good
Spark at all the plugs-Good
Brand New Plugs-Done
Checked PCM-Good
Everything is sparking and working good but It won't fire!!!!!! Anyone have any Ideas???
Old Apr 24, 2004 | 01:03 AM
1994TransAm's Avatar
ICM....
VATS......
Old Apr 24, 2004 | 01:04 AM
c0rey's Avatar
Ya if the vats was kicking in it wouldn't turn over would it?
Old Apr 24, 2004 | 08:18 AM
Max 93's Avatar
have you used a test light to make sure you are getting a signal from the PCM at the injectors? ( noid light)
Old Apr 24, 2004 | 09:25 AM
NOMAD's Avatar
If the car is cranking but not firing, buy a new ICM. Its the plug in part on the coil bracket. They usually run $60 from Advance auto and has a lifetime warranty.
-Shannon
Old Apr 24, 2004 | 01:50 PM
c0rey's Avatar
Its getting spark at all cylenders just wont fire up..
Noenav
Mar 1, 2019 07:38 AM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
