LT headers,cam, exhaust for 94 have questions
Old Apr 21, 2004 | 08:03 PM
BeerMan's Avatar
My broter-in-laws boy wants me to do 1600.00 worth of mods to his car. 94 Camaro six spd. He is in the service in Germany. I do not have his car yet but am buying parts. Does a 94 have Square or flat O2 sensor connectors? Also any advice? Here is what I was going to do. Pacesetter coated LTs and Y pipe, LT4 knock module, O2 extenders (flat or sq?), SLP LT1 Resonator cat back, Comp Cams 07-502-8 in .218 ex .224, Timing set, Comp cams 1417-16 1.6 rrockrs, 7608-16 pushrods, 983-16 springs, retainers, valvelocks,seals.
I had a 95 Z28 but never did internals. In your guys opinion am I missing something or will this stuff work. I do not want to buy Valve covers and I do not know if these Roller Rockers fit in stock.Any advice would be appreciated.
BeerMan
Old Apr 21, 2004 | 08:10 PM
BiGGinZ's Avatar
I would say also find a used or new cai. They are the best bang for the buck IMO. But those other mods sound good. Its sad but I don't know the answers to your questions even though I have a 94. I haven't gotten that far on my car yet. Good Luck man.
Old Apr 21, 2004 | 09:08 PM
b-stevens's Avatar
I'm not quite sure on the o2 question, but some people do have problems with the 1.6 rr's not clearing the supports in the valve covers, and most have ground away at them with a dremel. If you ask around a bit I'm sure people will be able to help you with details on that.
Also, you would probably want to look into having it tuned after installing the cam. I'm not sure if you have tuning capabilities or the knowledge to do so, but I suppose now would be a good time to learn.
Old Apr 22, 2004 | 05:53 AM
Mtrhds94Z's Avatar
My 94 has flat O2 connectors..
Old Apr 22, 2004 | 08:38 AM
97Z-pimp's Avatar
They are flat. i learned the hardway and got the square ones.
Old Apr 22, 2004 | 09:01 AM
Riddlerlt1's Avatar
you should have the flat O2 connectors. i believe the only square ones are on the BACK O2's on 96-97 OBDII cars behind the cats
Old Apr 24, 2004 | 02:25 PM
97Z-pimp's Avatar
exactly
Killer94z
Jan 13, 2015 12:06 PM
92ragtop
Dec 27, 2014 01:56 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
