golen engine owners. help!
Old Apr 18, 2007 | 04:11 PM
irishz28's Avatar
i just got my engine back from golen after i pretty bad mishap (not golens fault), and i had noticed that when i seperated the trans from the engine the pilot bearing had been pushed back in the bore in the end of the crank. the bore is deeper than the stock crank was. last time i just put a few tick marks in the bore to get the bearing sitting tight and flush with the end of the crank, but that dident seem to work. has anyone had this problem befor. i was thinking about putting a spacer behind it.
Old Apr 18, 2007 | 04:17 PM
crushah's Avatar
I'd give the guys at Golen a call and see what they say, they may have what
you need in order to correct the problem without having to rig something up.
Old Apr 21, 2007 | 07:49 AM
irishz28's Avatar
has any one out there had this problem?
Old Apr 21, 2007 | 10:56 AM
96ZCamaro's Avatar
I've never heard of somthing like that. But yea I agree with the other, call up golen.
Old Apr 21, 2007 | 11:04 AM
JP95ZM6's Avatar
I've heard of one example where the pilot bushing was a loose fit in an Eagle crank. That could do it. Was the bushing nice and tight?
cheapchevy
Apr 8, 2015 08:48 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
Reno Leigh
Jul 2, 2002 12:01 PM
