Car starts really slow....like a dead battery
Old Jan 9, 2004 | 11:24 PM
AlexsZ's Avatar
Not sure what the deal is, car is sometimes really really slow to start, will take like 2 seconds just to turn over once...then twice...then fire up really sluggishly.
I thought maybe i needed a bigger battery due to the increased pressure from the cam (had the optima Red top battery, rated at 840cca) so I went and bought a 920cca battery, had to squeeze it to fit (and screwed up my hood a bit too ) and it still seemed to start sluggislhy, but not as often.
Could it be my fuel pressure on startup? Or how about my cranking advance? It doesnt ALWAYS start slow, sometimes it'll start right up.
Old Jan 10, 2004 | 02:22 AM
Tony Danza's Avatar
if its the fuel pump thats the problem the cranking speed will still be high and will keep cranking untill it finaly has enough gas. Clearly the battery is a new and charged. I would look into it as being a mechanical issue with the starter deciding to work sometimes and not others.
Old Jan 10, 2004 | 02:44 AM
MentalCaseOne's Avatar
slow cranckin speed with plenty of juice in the battery?
The starter would be my first suspect.
Marvin
Old Jan 10, 2004 | 10:11 AM
Josh-'04 GTO's Avatar
Marvin
My first guess too. Don't forget to check the ground and power cables down by the starter.
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
