Car starts and dies
Car starts and dies
My 93 will start up and then die, sometimes it will start up just fine and run fine, other times I can get it started and rev it up but it wont idle and runs kinda rough. I have replaced the plugs and wires, The plugs are getting spark. Do you think it could be the ICM??
Taylor
Taylor
could very much be. when my icm took a dump, the car would turn on but wouldnt go over 3k rpm's. it would die as soon as it hit 3k. in D or in P. if you have a friend with an lt1 swap coils with icms to see it if fixes it.
icm
No you can not i just bought one i am haven same problem this week i replaced the coil.Icm.fuel pump regluter still have the problem but there a differce in the icm get one for a 93 good luck if you find the problem out let me know the same here
Ok now the car doesnt even start, it will act like it is going to start then backfire. I havent gotten to try a different ICM yet, but I know the plugs are getting spark. I bought this car about a month ago, it ran bad so I replaced the plugs, 3 were orginal with 118,000 miles on them, it ran great after that, then it started to miss so I decided to change the plug wires and the exhaust manifolds leak so I figured take them off and replace the gaskets and plug wires at the same time. So when I was doing that I found one or two plugs that were backing out so I figured that was the problem, well I got it all back together and it wont start. I check the wires and they are in the correct spots, I did them one at a time. I cant figure this out, I guess tomorrow I am going to buy a new ICM.
Taylor
Taylor
i know that a 94 coil/icm will work on your 93. we took the coil with icm off my friends 94Z and put it on mine. it it fired right up.
so i think other years could work too?
after a while my car wouldnt start either. sounds like we have the same problem.
man that sounds EXACTLY what happened to my car a couple of months ago, it was the icm, i bought one from napa and put it on it did the same thing, turns out that napa sold me a bad icm, and it took me a month to figure out that the one they sold me was bad
fpete1992
Dec 11, 2014 03:51 PM
teedoff59
Aug 8, 2002 01:36 AM
