Car stalls at launch
Old Aug 22, 2005 | 07:25 PM
scmudslinger's Avatar
I have a 93 Z28 that is stock except for a CAI. I have noticed recently that upon a hard launch, the car will nearly stall several times initally, and finally gets going. The car has also completely stalled twice, and when this happens, the engine turns over a long time (2-3 seconds) before it fires up. It seems like this could be a fuel problem to me, or I could be completely off. Anyone got any ideas? Thanks for the help.
By the way, I recently took another user's advice and cleaned my MAP Sensor, an idler control (can't remember the name), and cleaned my intake manifold and throttle body with Sea Foam carb cleaner to help eliminate the problem, but it apparently failed.
Old Aug 22, 2005 | 09:08 PM
Re: Car stalls at launch
Old Aug 23, 2005 | 12:06 AM
OBE1 95Z28's Avatar
Have the car scanned and look at your knock readings. If your getting knock, the computer will pull timing and cause the car to stumble.
Old Aug 23, 2005 | 07:00 AM
Thank you for the help.
Old Aug 23, 2005 | 09:18 PM
Anyone have any technical advice?
Old Aug 23, 2005 | 09:31 PM
1racerdude's Avatar
Fuel problem or stopped up converter in the exhaust.
Noenav
Mar 1, 2019 07:38 AM
mark0006
Dec 25, 2014 09:50 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
