Car Stalling
Old Jan 7, 2005 | 12:53 PM
Ripcurl3249's Avatar
Car Stalling
i have 96 Z that stalls around 1,000 to 2,000. every once in a while even when the motorswarmed up. if i got msd and a blaster would it help.
Old Jan 7, 2005 | 01:04 PM
red 95 z28 lt1's Avatar
Re: Car Stalling
msd may not help. you need to find the problem first. check coil, opti, maf, icm, when was your last tune up, what year how many miles, need more info
Old Jan 8, 2005 | 02:45 PM
Re: Car Stalling
Its a 96 Z28 camaro w/ 112,000 miles.
Old Jan 8, 2005 | 11:29 PM
Re: Car Stalling
but when was ur last tune up. was your opti ever changed if so how long ago
Old Jan 9, 2005 | 05:36 AM
redfirehawk101's Avatar
Re: Car Stalling
Every once in awhile huh! Sounds like an EGR valve going bad. My car did the same thing.
Old Jan 9, 2005 | 12:36 PM
Re: Car Stalling
i never replaced my opti
Old Jan 9, 2005 | 03:43 PM
Re: Car Stalling
Bad Optis tend to be hard to troubleshoot! Rule out the EGR first! Bypass it by removing the two screws that are attached to the back of the manifold and place a piece of metal cut out to fit the hole and retighten this to see if this helps. If it does it is the EGR valve. Just because you have a lt1 with a 112,000 miles on it does not mean the opti is bad. Good Luck on your car!
Noenav
Mar 1, 2019 07:38 AM
Injuneer
Dec 15, 2014 09:36 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
