Car sounds like a desil inside.
Old Jan 8, 2004 | 03:09 PM
dragon93308's Avatar
I put my wet setup on yesterday. I started my car and everything worked and sounded fine from the inside. When i went to drive it i started it up and closed the doors and noticed that it sounded just like a desil. I steped outside to check and it sounded normal there. Inside it still sounded like a desil. The sound increaces and gets faster with higher rpm.
Old Jan 8, 2004 | 03:14 PM
TraceZ's Avatar
Is it preignition?
By wet system, do you mean a nitrous setup?
Old Jan 8, 2004 | 03:37 PM
When it is running. Yes nitrous.
Old Jan 8, 2004 | 08:48 PM
can anybody help me on this?
Old Jan 8, 2004 | 09:52 PM
longwaytofall's Avatar
the correct spelling is diesel, btw. did u just hook up the nitrous system? or actually use it?
Old Jan 9, 2004 | 01:10 AM
just hooked it up havent used it.
Old Jan 9, 2004 | 01:24 AM
Sacramentoz28's Avatar
you sure you hooked up your WOT switch right? it could be spraying when you turn on your car. Just a thought.
-O
Old Jan 9, 2004 | 02:23 AM
hot_red_z28's Avatar
Your "problem" is not really a problem. It is a common thing in LT1's. It's sometimes referred to as "piston slap". The material the pistons of the LT1 are made of condenses when it is cold. I am assuming you live in an area where it prolly was pretty cold lately. With the pistons condensed, a bit of air can blow by the piston, which makes the noise. You might even hear a slight ticking type sound under the hood.
Mine does it each year just as winter starts. I put it up for the winter, so I don't get to hear it throughout the winter, but it always goes away once it starts warming back up. Also, if you start it and it is doing it, let the car warm completely up, till the fans kick on. By that time, the dieseling noise should be a lot less noticeable as the pistons have expanded to where they should be.
I was quite alarmed the first time I heard mind doing it, and this is the information I was provided with.
BTW, I wouldn't really mash on it at all while it's warming up if the weather is cold. If you are experiencing "piston slap", hammering on the gas is not a good thing to do until the car is warmed up. When mine is doing it, I never take it over 2k rpms until it has warmed up completely...
Hope this helps...
Old Jan 10, 2004 | 05:33 PM
No, it hasnt been cold here latley, its been around 70 for the high. I let my car warm up for about 20 minutes and it still does it. It never goes away.
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Klypto
Jul 24, 2002 11:21 AM
