Car shuts off when braking and stopping
Old Oct 22, 2006 | 07:49 PM
  #16
mmmchickenboy's Avatar
Re: Car shuts off when braking and stopping
could be a vacuum leak, too.
EDIT: "The symtoms resemble a vacuum leak, i.e. IAC, vacuum line, manifold gasket, etc"
Old Oct 22, 2006 | 07:52 PM
  #17
turbo_Z's Avatar
If the IAC is maxed out... thats why the idle dropped and your motor stalled.
Old Oct 22, 2006 | 09:17 PM
  #18
busta9876's Avatar
you stated iac count of 160 earlier.
You need to adjust your throttle blades untill you get a HOT idle around 40 counts.
I have a friend with a 383, stock headed LT4 hot cam and 58mm tb, we had to adjust it to 20 counts HOT in park because when it was cold outside, the IAC couldn't open enought to keep it running.
He also had an adjustable TPS sensor, so opening the throttle blades didn't cause any problems with TPS sensor.
good luck.
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
fpete1992
Dec 11, 2014 03:51 PM
USAirman93
Nov 24, 2014 03:37 PM
