Car shuts off when braking and stopping
Old Oct 20, 2006 | 07:11 PM
Honda Hunter's Avatar
Every time I come to a stop the car shuts off. Just driving for 3 minutes Ill hold the brakes to stop and the idle rpm's drop really low and shuts off. What could be causing this?
Old Oct 20, 2006 | 07:56 PM
Chevycobb's Avatar
Re: Car shuts off when braking and stopping
probably fuel related. I would go ahead and replace the fuel filter. When I had that happen to me thats all it was.
Old Oct 20, 2006 | 08:01 PM
OBE1 95Z28's Avatar
Your IAC (idle air control) could also be dirty or malfunctioning. It mounts in your TB.
Old Oct 20, 2006 | 09:41 PM
busta9876's Avatar
check your VSS (vehicle speed sensor)
if the computer see's no vehicle speed it thinks it is ideling.
when you are on the decel, throttle closed, it will run the IAC all way closed trying to bring the engine rpm down, but it can't because you are on decel.
On LT1 swaps I have done without an VSS hooked up I had that exact problem, and have watched it do it on datalogs.
By the time you slow down enough that the rpm goes to desired idle, the IAC can't pick up fast enough.
try coming to a stop with one foot on the gas holding the throttle slightly open. It will probaby stay running fine.
Could try your cruise..my bet is it won't work, because your vss is bad. or a wiring problem
good luck
Old Oct 20, 2006 | 09:47 PM
good luck
VSS is hooked up. Speedo works although it's way off due to a rear end change but Ill take a look at it.
Old Oct 21, 2006 | 01:10 AM
Fuel pump and fuel filter are new and fuel psi is at 39. IAC is the only thing I havent had a chance to check.
Old Oct 21, 2006 | 09:13 AM
Finally got the Datamaster to work. IAC count had to stay maxxed out to drive it. It surged and sputtered at part throttle, it jump in and out of closed and open loops, BPW mS reading was in the yellow, and I had DTC 15 cool temp low. Anyone here good at reading this? I'm about to throw it into VEMaster.
Old Oct 21, 2006 | 01:08 PM
OBE1 95Z28's Avatar
Your coolant temp low code is the reason you're jumping in and out of closed loop. You may have a bad temp sensor (the one in the waterpump) or a bad wire or connector to the temp sensor.
Old Oct 21, 2006 | 01:12 PM
During my 10 minute drive today the highest the temp got was 187. Here's the datalog:
http://d.turboupload.com/de/1110032/upfk3iozie.html#
Old Oct 21, 2006 | 08:10 PM
CamaroUK's Avatar
Just a thought, but I think a bad EGR valve can cause a car to shut off when coming to a stop. I had this happen to me on my old TBI camaro, Something else to check I guess.
Old Oct 21, 2006 | 10:27 PM
I dont have the EGR valve.
Old Oct 21, 2006 | 10:36 PM
Rage's Avatar
Altenator. Maybe. Check the guage when you stop.
Old Oct 21, 2006 | 10:40 PM
Volts are perfect.
Old Oct 22, 2006 | 02:09 PM
Could the valve lash be to blame? Could it cause these issues?
Old Oct 22, 2006 | 06:45 PM
Severous01's Avatar
i had a vacuum problem with my auto.....one of the vacuum lines was cracked and when i replaced it my TC decided to unlock when i took my foot off the gas. when i would come to a halt or even at idle the car would sputter and sometimes die if i didnt hit the gas a little. no more
