Car runs, then quits
Old Jun 19, 2004 | 04:50 PM
95_LT1_6SPD's Avatar
I just replaced the intake gaskets to fix the rear intake oil leak, and went to start it up. It starts fine, idles for about 1-2 seconds then cuts out. It will fire right back up and do the exact same thing. It is not showing an ses light either.
I did notice that right after it dies, the fuel pump kicks in again. There are no fuel leaks or anything, and i am 99% sure i have all the vacuum lines connected properly, i am gonna download the pics off my camera and verify.
I read that the best way to check the fuel pressure regulator is to pressurize the system, and then pull the vacuum line off it. If fuel comes out its crap. Nothing squirts out mine. I am gonna go to town tomorrow and get a Fuel pressure gauge to see what its at.
Is it possible that the vacuum lines are connected wrong causing it to kill itself?
Old Jun 19, 2004 | 05:47 PM
scoobysnax83's Avatar
Re: Car runs, then quits
Probably not... Do you have the oil pressure sending unit disconnected?
Old Jun 19, 2004 | 06:46 PM
I found the problem, the air silencer wasn't connected. Who would have thought that would cause it to kill itself and get me all worried
Old Jun 19, 2004 | 10:54 PM
that makes sense. If you would have unplugged your MAF it would have ran. It was sensing too much air entering the engine and flooding itself out. Your car is smarter than you think...
ro2207
Dec 4, 2014 06:18 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
