Car runs rough then dies
Old Feb 4, 2005 | 05:30 PM
whiteslpz's Avatar
Question Car runs rough then dies
It was a nice day today so I decided to put the battery in my car and start it and let it run. It ran fine for about 20min then it started to run rough going from 600rpm up to 2000rpm it did that a couple times then it died. The gas has stable in it and the battery was out of it and it ran perfect before I put it away so if you have any ideas thanks Jason
Old Feb 6, 2005 | 09:02 AM
JDman's Avatar
Re: Car runs rough then dies
As you can see I'm posting the same problem ie;"Stalling problems" posted 2-5-05. I'm told it's the Opti I wonder how difficult it is to change.?
Old Feb 6, 2005 | 09:41 AM
indieaz's Avatar
The opti isn't difficult to change - just time consuming. You can try a search - there's a lot of posts on changing the opti (probalby more on that than just about anything else). Basically you need to remove the water pump, AIR Pump, then pull harmonic dampener and remove opti. To pull the dampener you do need a balancer puller tool - you can borrow one @ autozone etc. if you don't have one.
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
