Car runs horrible after header gasket change
Old Aug 11, 2006 | 11:02 PM
Grims's Avatar
Driver said header gasket blew so I changed it with a copper gasket. After I got done I took it for a drive and it was running HORRIBLE. It reved very choppy, accelerated like a dog, with a slight vibration, which got worse if I opened the cutout (much worse)
I took it back, checked out all the wires and sensors on that side, they were all good and I have no SES light.
Any help would be great, I it need running by tomorrow...or it (the girlfriend) is going to kill me.
Old Aug 11, 2006 | 11:28 PM
camaroman4ever's Avatar
Re: Car runs horrible after header gasket change
make sure you didn't crack or unhook the temperature sensor in the head. fairly common for that to happen.
Old Aug 11, 2006 | 11:30 PM
Grims's Avatar
It has always been kind of messed up (broken clip) but it's not leaking.
Old Aug 12, 2006 | 01:52 AM
hvyss's Avatar
Mine did the same thing after installing the Mr gasket copper header gaskets. Took them out and every port was leaking on the bottom side. Bought some high temp copper rtv and put sealant on both sides of the gasket and reinstalled them. Let it sit for about an hour and restarted the car and runs 100% better. I bet the gasket is leaking. Good luck.
HVY SS
Old Aug 12, 2006 | 09:18 AM
Kevin Blown 95 TA's Avatar
Here's what my copper gaskets looked like. You can see they don't fit and leak out the bottom.
Old Aug 12, 2006 | 09:44 AM
2000GTP's Avatar
I would just make sure the header gasket is seated properly and the bolts are tightened. Double check that all the plug wires are seated properly. If it is leaking, it will cause driveability problems. The temp sensor in the head only gives input to the dash gauge so even if you did knock it loose or damage it, it shouldn't effect your drivability.
Old Aug 12, 2006 | 06:32 PM
Grims's Avatar
Okay, I have tried 3 more times, the copper gaskets just will not seal. I'm leaking from every port, especially number 1. Maybe theses copper gaskets jsut don't work well with the thin flanges on the pacesetters. The car isn't even dirveable like this, and is backfiring like crazy.
I ordered some Felpros and will try them tomorrow.
Old Aug 12, 2006 | 07:45 PM
The problem with the gaskets is that they are probably shaped to fit the stock manifolds, and the headers have bigger ports at the bottom. The bottom part of the embossment on the gasket crosses above the lower part of the header opening and breaks the seal.
Old Aug 12, 2006 | 07:48 PM
Grims's Avatar
I have read lots of posts where pople swear by theses on headers...why I got them.
Old Aug 12, 2006 | 08:24 PM
Might depend on the particular headers whether they seal or not. Some guys might be having good luck with them, some dont, and some probably don't know. It wasn't real evident on my installation - you couldn't hear any ticking and the car ran fine. It wasn't until I pulled them off that it was noticeable, so I didn't reuse them.
Old Aug 12, 2006 | 08:27 PM
Grims's Avatar
Gah, mine feels like a civic, and shakes the car.
Old Aug 13, 2006 | 12:17 AM
camzaro28's Avatar
sounds more like a burnt plug wire then a leaky header gasket.
Old Aug 13, 2006 | 12:25 AM
1racerdude's Avatar
Ya might have broken a plug or burnt a wire.
Old Aug 13, 2006 | 05:30 PM
Grims's Avatar
Put on some Felpros, and everything is fine now.
Old Aug 15, 2006 | 08:07 AM
tim95z28's Avatar
Yep, I put those on with rk sport headers and leaked horribly. They do not work.
