Car running rich
Old Sep 21, 2003 | 03:04 AM
BiGGinZ's Avatar
Question Car running rich
My car is running very rich. I need to fix it but I don't know what to fix. The idle is a little rough too. Any help would be great.
Old Sep 21, 2003 | 10:05 AM
LT1 Tech problems belong in LT1 Tech. Moving it there.....
How do you know its running rich? Under what conditions - idle, part load, WOT?. Have you ever had it scanned? Do you have data for the long term fuel corrections? Have you checked the EGR valve for leakage?
Old Sep 21, 2003 | 10:46 AM
joeSS97's Avatar
Any codes?SES light?.I am going to guess the O2 sensor is bad.How many miles on it?You really need to give as much info as you can in order to give us a clue.
Old Sep 21, 2003 | 03:02 PM
BiGGinZ's Avatar
The car has 119,000 miles. The ses light comes on sometime but not all the time. After I drive it I can smell heavy gas. I took it and had it looked at and all they told me was that it was running very rich. Do you think a tune up might do the job?
Old Sep 21, 2003 | 11:06 PM
ead94z28's Avatar
If you have original O2 sensors you should replace them anyway and it might fix the problem. Also check your cat. I am getting a strong fuel odor (running rich) and when I took it to meineke. They said it looked like the previous owner gutted the cat. I am going to put a new high flow in. Hopefully it helps
Gene
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
