Car running Lean?
Old Jul 9, 2003 | 06:33 PM
unTAmedLS1's Avatar
Car running Lean?
So all of sudden one day the airfuel just sits at lean and I am getting a blinking ses so I have a misfire but all plugs and wires are fine. So I pulled the plugs to make sure it really was running lean and not just a bad O2 reading or something. And sure enough all plugs were white so its running lean. all injectors ohm out fine. Why else could this be happening?
Old Jul 9, 2003 | 09:35 PM
unTAmedLS1's Avatar
TTT PLEASE HELP
Old Jul 10, 2003 | 12:20 AM
Low fuel pressure. Faulty signal from MAF. Huge vacuum leak.
Check the fuel pressure. Then get is scanned and look at the long term fuel corrections and MAF gps values under different driving conditions. Also look at MAP at idle.
Old Jul 10, 2003 | 02:15 AM
unTAmedLS1's Avatar
iT WAS A BAD o2 ON PASS SIDE giving way rich readings so the ecm was leaning everything out.
Old Jul 10, 2003 | 02:17 AM
unTAmedLS1's Avatar
Oh yeah and my lts on that side hit peak 25% then would gradually hit bottom then back to peak again and same with st trims would hit 50 percent then down then back up again. So the 02 is definately bad
Old Jul 10, 2003 | 05:26 AM
unTAmedLS1's Avatar
Sounds right....right ?
Old Jul 10, 2003 | 07:50 AM
scoobysnax83's Avatar
If you hadn't said it. I was gonna....... So yes it sounds right.
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
