Car is running hot!!!!!!!! :mad:
Old Jul 31, 2004 | 12:17 AM
jasons93z's Avatar
OK, ive flushed the system, bleed it, and it still is running hot. WTF. Btw, im running about 25/75 coolant/water. I also put in a bottle of water wetter. It did nothing. The temp usually gets up to about the 3/4 or a little past(close to the red), but if i turn off the a/c it stays between 1/2-3/4. It use to run around the 1/4 mark. I have the fans set and the 160 stat. The temp outside has been around 88. Whats going wrong, any guesses??????
Old Jul 31, 2004 | 12:39 AM
jasons93z's Avatar
Re: Car is running hot!!!!!!!! :mad:
Anyone know??
Old Jul 31, 2004 | 10:06 AM
Fuels94TA's Avatar
If you think you have done everything correct how about the thremostat. When was the last time it was changed out? Another thing also is did you change out your plugs lately? The reason is there is a small temp sensor between plug #1-#3 that's easy to break if not careful.
Vinny
Old Jul 31, 2004 | 10:14 AM
n2ceptor's Avatar
You might still have air in the system.... Turn your heat on and check your fluid level, it might have went down... Thats what happened to me...
Old Jul 31, 2004 | 11:54 AM
RyanS_Z28's Avatar
do you have an aftermarket electric water pump? how old is your thermo? my AC has been draining my battery quite a bit lately and my car runs about halfway up the guage with it on for extended periods on high. thats what happens when you live in texas. if the car isnt "overheating" then just tone down the AC, roll the windows down more often for natural interior cooling, make sure all of the air is out of your tubes
Old Jul 31, 2004 | 12:23 PM
sc93's Avatar
I thought you were supposed to do 50/50 coolant/water
Old Jul 31, 2004 | 12:26 PM
RyanS_Z28's Avatar
if he is running with problems though there is no sense in wasting coolant if he is burning any. as long as he has a significant ammount of coolant and water its ok.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Dec 17, 2014 01:12 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
