Car running hot after LT4 KM install
Originally posted by TMDZ28
no you dont...just get it reprogram from someone who has tunercat for free.....honestly, no need to spend $300 for lowering your cooling fans
Spinner, check to see if it has a t-stat, somebody may have removed it and they dont cool properly without one. Also, check the air deflector on the bottom of the car, make sure its there, those parking lot curbs like to eat them. When you check/ replace your t-stat you'll need to bleed it for sure then so just plan on it.
Generally, retarded timing will make an engine run hotter/warmer. I'm not sure why the LT4 knock module would pull timming. Actually putting the origingal k.m. back would be my first step just to verify if that was causing the higher temps.
Hope tat helps.
Hope tat helps.
Marvin
I had the same problem with my car the first night i had the Cam (cc 305) in. It started fine and drove good but it was runin hotter than sh*t! I couldn't figure it out, i have a 170* stat, TB bypass, SLP fan switch and Meziere elec. W/P.
Turns out i hadn't topped of my coolant, and thus also bleed the system. That was my probs. after installing a cam.
Hope this helps
Turns out i hadn't topped of my coolant, and thus also bleed the system. That was my probs. after installing a cam.Hope this helps
Something a lot of folks forget is to replace their pressure cap. If it is not holding pressure you can definately have over-heating problems. The F-Body stock cap is 18 psi which is really high compaired to most. A new cap is only a few bucks and is cheap insurance.
Good Luck
Good Luck
ro2207
Dec 4, 2014 06:18 PM
