car running bad when warmed up
Old Mar 17, 2004 | 10:37 AM
badblackta's Avatar
I have had this problem for sometime. When I first start the car in the morning it runs great, like it is supposed to. But after it warms up it starts to stutter and miss at idle and miss when accelerating. The plug wires arent arching anymore, I have checked. New fuel filter,new plugs and wires. Seems to be running rich. Not sure what is going on with it. The opti is like a year and a half old. Any suggestions?
Old Mar 17, 2004 | 10:58 AM
Anderson's Avatar
It has to be the Flux Capacitor if its not the opti
Seriously, my next guess would either be the coil, or the Ignition Control Module from heat soak. Neither of the 2 are expensive.
Old Mar 17, 2004 | 11:33 AM
HBHRacing's Avatar
I would do a fuel pressure test and rule out fuel system problems. does kinda sound like opti tho. did you replace the whole unit? coil would also be a logical next step
Old Mar 17, 2004 | 11:47 AM
badblackta's Avatar
Well I thought it was the coil too, so I got an msd coil for it but that was not it. Could it be something fuel related?
Old Mar 17, 2004 | 12:00 PM
HBHRacing's Avatar
it;s possible.. thats why I always sugest a pressure test to make sure it;'s worrking correctly. it;s very easy to rule out a pressure problem. if thats all good we can go from there.
but did you install a compelate new opti or just a cap and rotor kit?
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
Brent94Z
Mar 21, 2002 04:44 PM
