Car and rotor rubbing on only one side..
Old Aug 19, 2005 | 01:03 PM
Whitewolf's Avatar
what would cause the opti to be rubbing on one side and destroying the rotor button? I have posted a time or 2 on this but upon further investigation looks like it is only rubbing on one side..I had been replacing cap and rotor but this time got a all new opti..running ok so far. but if the dowel pin was too long it would cause it to run all the way around right? if it does it this time I am taking the cam out and going with a bigger one while I have it out. Ideas on why it was rubbing on one side? maybe the shaft of the opti was slightly bent?
Brad
oh and check out my website see what you guys think...
http://www.tmanland.net/brads/
Old Aug 19, 2005 | 01:18 PM
bunker's Avatar
Re: Car and rotor rubbing on only one side..
There is a bearing, if it offsets then it will rub on one side.
Old Aug 19, 2005 | 10:22 PM
Whitewolf's Avatar
so if I replaced the whole opti unit it should be fine correct?
Brad
Old Aug 21, 2005 | 08:06 PM
Whitewolf's Avatar
Ttt
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
