Car revs by itself
Old Apr 12, 2004 | 11:41 PM
Quick96Z's Avatar
Angry Car revs by itself
Just did a cam and head swap, and now my car has zero hp. The computer was tuned PCM for less, so i know that is good. I went for a quick spin, and when i would let off the gas and push in the clutch to shift, the RPM's would jump to like 3000, and stay there until i engaged the clutch again to force the rpm's back down. Now that it is parked, i checked the oil, and it stinks like gas pretty badly. For some reason she is loading up pretty badly, and i bet it's washing out my cylinder walls too
Also, it idles, and rev's up just fine while i am parked. It spins all the way up to 5 grand and back down to idle just fine when i am not moving.
Any help would be great, i am completely stumped! What would cause my motor to rev like that all by itself??? Throttle isn't stuck
trav
Old Apr 12, 2004 | 11:53 PM
95lt1&99ls1's Avatar
if you have a buddy with another computer you might try that..
Other that that....... I've got nothing
Old Apr 13, 2004 | 12:22 AM
bunker's Avatar
sounds like bad IAC or leak between TB/intake or intake/heads. Basicly air intake leak.
Old Apr 13, 2004 | 09:08 PM
Quick96Z's Avatar
Air leak huh?? Why would this problem only show up when i am trying to move. It revs just fine while i am parked. Also, if i had a air leak, wouldnt it run lean, and not pig rich? I'm just trying to understand a lil more
trav
Old Apr 13, 2004 | 09:41 PM
tryintogofast's Avatar
Yeah a air leak would cause a lean condition BUT it's all in what the computer would look at. So if you have a air leak yes it would raise the RPM and actually make it run rich. The O2's would pick up the unburned Oxygen see it as a lean condition and throw more fuel into the engine to compensate henceforth causing a rich condition. But I don't know why it wouldn't run high at idle though. Did you change the injectors? I'm kinda stumped on that one. It sounds like a air leak but it "should" run a high idle if it was that. Also you part of the Minnesota F-Body club?
EDIT: Also possible your throttle cable is getting caught or the throttle plates aren't closing proper.
Old Apr 13, 2004 | 09:45 PM
HardcoreRM125's Avatar
Yea it would run lean, still though, thats the only thing I can think of that would make it surge like that ...
Did you happen to check compression on all your cylinders ? I know it sounds dumb, but that could explain the power loss ... Especially since you jsut did heads/cam ... That OR something fuel related ... What pump are you using? How much pSI at the rails ? I dont know a whole lot about the injecter pulse times and how to tell if your "overworking" an injecter, but look into that, it takes alot less gas to rev up in nuetral than in gear so ???
Old Apr 13, 2004 | 09:47 PM
Ha you work at checker can I get your 25% discount on parts? LOL I had to try
Old Apr 13, 2004 | 10:43 PM
FormulaLT-1's Avatar
unplug your cruise control fuse.
Old Apr 13, 2004 | 11:28 PM
ram air camaro's Avatar
Exclamation
it could be your optispark took a dump! or your opti
Old Apr 14, 2004 | 08:01 PM
Quick96Z's Avatar
I upgraded to 30# injectors. I called brian at pcmforless, and he said that it could be the throttle set screw. We did turn that screw out to make it idle right at first, so he thinks that i should move it back and see what happens. As far as the terrible loading up problem, i do still have the stock o2's, and they have 85000 miles on them. He said that maybe they are running a little weak, and making my car run pig rich. My water pump and opti and fuel pump were replaced last fall, and i've put about 2000 miles on them, so i know the opti and such are still in good shape.
I am going to be a member of minnesota F-bod club any day now....i just haven't gotten around to it yet. I plan on it though
I'm planning on replacing the o2's, resetting the idle screw, re-torquing the intake manifold bolts, and i picked up a new throttle body mounting gasket. I get 25% off, and i am due on a few of those things...hopefully it will work.
By the way, if some of you guys buy high enough volume, i can set you up with a commercial account....it starts off small, but can build into a pretty decent discount.
let me know if you are in the northern suburbs of minneapolis/st.paul
trav
PCLZ28
Dec 24, 2015 05:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
USAirman93
Nov 24, 2014 03:37 PM
