car revs on its own?
Old Jun 13, 2014 | 08:08 AM
  #16
Re: car revs on its own?
Originally Posted by lovemyblackz28
Not sure how these things work. I brought the car into my mechanic. He said he disconnected the idle control and the car was idling fine after that.
If he left it like that, he is no mechanic. As Fred suggests, there may be something else that is causing the IAC to react.
Old Jun 17, 2014 | 11:08 AM
  #17
lovemyblackz28's Avatar
I havent had a chance to take the car in yet. What are the other possibilities that would cause the issue?
Old Jun 17, 2014 | 03:00 PM
  #18
I just helped someone on another site, similar problem (except it was revving up as high as 1,800 RPM). We went through the data logs, couldn't find anything. He gave up, replaced the Opti - problem solved.
Old Jun 17, 2014 | 03:05 PM
  #19
I was afraid you might say that. I had an issue with the car bout 5 years ago, it would hesitate on the highway when I would give gas. I replaced the opti and plugs and wires and all was well. How often do these cars need tune ups?
Old Jun 17, 2014 | 03:58 PM
  #20
Look through these threads - similar problem:
https://www.camaroz28.com/forums/lt1...t-work-879506/
From bad to worse
In the second link, go to post #30 on page 3:
Oh yeah, she's back, she's running good so far. Big difference with the gears, and now with the delco it has the crack to it when you start it. Found a few things I missed with this build, header touching motor mount and now the little 3-2 Hangup is there a lot more with the gears, but so far so good. Thank you to anyone who threw ideas out, it was definitely the opti.
Old Jun 17, 2014 | 03:59 PM
  #21
What brand Opti did you use for the replacement? How many miles on the replacement at this point in time?
Old Jun 18, 2014 | 10:09 AM
  #22
I believe the opti is an AC delco. I put maybe 15000 miles on it.
Old Jun 18, 2014 | 11:03 AM
  #23
OK. The guy who solved his surging problem with an Opti replacement had an MSD Opti when the problem cropped up, and it happened right after MSD had rebuilt the unit due to previous problems. He replaced it with the Delco and the surging disappeared.
Does your tach display a little "twitch" just before the surging starts?
Old Jun 18, 2014 | 11:34 AM
  #24
actually, it does twitch before the surge. It looks like it does a little bounce up and down before it goes up.
Old Jun 20, 2014 | 11:56 AM
  #25
Replaced the IAC. problem still occurs. Guess it's time to order a new opti. What's a good site to order that from?
Old Jul 7, 2014 | 10:21 AM
  #26
UPDATE:
Finally put in new opti and all is well. Thanx for the suggestions.
Old Jul 7, 2014 | 11:09 AM
  #27
moparman's Avatar
Hope you put in an ACDelco or Delphi opti.
Old Jul 7, 2014 | 11:23 AM
  #28
UPDATE:
Thanks for the feedback!
This is the same result on three different cases on two sites that I frequent - all three in the last three weeks. The other two were traced to MSD Opti's. Did you verify that your old, problem unit was an AC Delco?
Old Jul 7, 2014 | 01:51 PM
  #29
The old unit was an AC Delco. I dont understand any of this mechanical stuff really, my mechanic said the bearing in the distributor cap wouldnt turn so well. Not sure what that means. Im just happy its all good now!
Old Jul 7, 2014 | 04:42 PM
  #30
The bearing is in the base of the unit. But it supports the drive shaft and the shaft the rotor, and the optical shutter wheel for the cam position sensor spin on.
