car revs higher than it should when cruising
Old Apr 26, 2004 | 12:06 AM
  #16
94ZRiCeKiLr's Avatar
Originally posted by badblackta
how does the lock up switch work and does that improve performance very much?
the lock up switch manually tells the solenoid to lock the converter when you flip it, as opposed to when the car tells it to. its usually worth about a tenth of a second. you can only lock the converter at the very top of a gear or else the extra drag will bog the motor down. if you do it right however, you'll get a little extra boost as the power from the engine will be more efficiently transferred to the wheels once the converter stops slipping.
sorry i can only give you bits and pieces bad black....i know a little about everything and everything about very little.
Old Apr 26, 2004 | 12:26 AM
  #17
scoobysnax83's Avatar
thats my story
jayblev95
Jan 20, 2015 01:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
