Car ran bad , now wont start
About 2 months ago my a4 93 lt1 was fine, I let it sit for a month (in the below freezing michigan weather) I start it up and the car run like its on 7 cylinders, ,it would shake and run like **** under a load. When the car was in N or D it would idle fine. Now when I go to start it , it will crank but wont fire, I hear the pump working and smell gas. my coil is good. I bet this whole thing is an opti problem.
Think about it, first the car seems like it running on 7 cylinders now it wont start
any ideas? , Id hate to replace an opti when its not the problem
You have spark where, at the coil or the plugs after the opti. Try squirting fuel into the intake and crank it over. If it starts after you squirt fuel in the intake and shuts right back off, you have fuel problems and probably the fuel pump.
supercharged94Z28
Feb 24, 2003 10:22 PM
