Car Quest Oil Pan Gasket
Old Mar 24, 2004 | 11:33 AM
ponyackn's Avatar
I just bought a oil pan gasket from them. It is rubber and specific to the lt1. Do you think it is as sufficient as an oem? It was a like $10 less than the dealer. Should I just go to the dealer or is a rubber gasket a rubber gasket?
Old Mar 24, 2004 | 11:41 AM
jtk's Avatar
jtk
it will be fine as long as the bolts are thightened as they should and silicone is applyed around the corners and ends. the only way for a one peace gasket to leak is having the bolts come loose or the silicone at the ends stops sealing
Old Mar 24, 2004 | 11:49 AM
ponyackn's Avatar
Ok, that's good to hear. Thanks jtk.
As far as the sealant is concerned, how do you make sure it's a good seal? Looking at the leak area, I even had excess sealant hanging over the lip of the half moon area and it still leaked. Maybe I used too much last time?
Old Mar 24, 2004 | 12:08 PM
chy20k1's Avatar
car quest is good stuff, ive used it for years
Old Mar 24, 2004 | 01:00 PM
DR.ZED's Avatar
Ahhh... real gaskets don't require silicone.
... IE> Felpro oil pan gasket.
Old Mar 24, 2004 | 01:11 PM
LilJayV10's Avatar
Car Quest stuff is fine, we use their stuff everyday at our shop. You'll find that Victor Renz makes that gasket.
Old Mar 24, 2004 | 01:14 PM
ponyackn's Avatar
Yup, it's that victor reinz gasket. Car quest told me that the local dealerships usually call them for parts like that as well.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
Elcojoe
Nov 17, 2014 10:27 PM
