!!--Car Problems after storage and new plugs--!!
Old Mar 25, 2004 | 11:19 PM
Bersaglieri's Avatar
My car has been stored for the winter and I got it out today. I recently changed the plugs (NGK TR55 GP's Platinum) and changed the oil (K&N filter and Mobile 1 5w-30). Battery was unhooked for 1.5 days during plug install. And I started it every couple weeks and let it warm up.
The problem started really bad and slowly got better but not cured.
We went to get gas cause I was almost empty (We changed the fuel filter tonight also) and under a load the car felt like it had no power and wouldnt shift right or shift at all. Once it would get to OD it was hard to get it to downshift. The only way to get it to run right was to floor it.
I got gas came home and took a look. It was surging all over the place. So we check the wires and plugs and change the fuel filter. Nothing still surges. Then we check the intake elbow since I had it off during the plug install(i though I needed to get to the opti that way) We thought it was the IACV but have no way of checking it to my knowledge. We found that the elbow wasnt on completely and fixed that. Still surged. Thought maybe it was the computer trying to refind its idle, but not sure. So we took it and ran it hard for a while to try to get it warmed up...the more we drove it the better it got...but it still stumbles at low rpm and misses a bit. We can hear a tick or click in the valve train and it is noticable after a rev when the engine is winding down.
If you have any idea what the problem is please post. My car is right outside so if I need to try something please let me know.
Thanks a ton guys..I also have a cell phone that I'll be willing to call someone if I need a walk through.
-Dustin-
Old Mar 25, 2004 | 11:41 PM
bpipe95's Avatar
water in gas tank
when it is stored for a period of time with out a ful tank you can get condesation* and when you filled it all mixed with the gas
it should get better.....
Old Mar 25, 2004 | 11:44 PM
Yes we also suspected that...we were thinking run one tank through then refill and adding "outlaw"
Thanks alot for the response
-Dustin-
Old Mar 26, 2004 | 11:05 AM
Now the car just stumbles under load at low rpms 1000 to 2500. Misfires a bit at highway speeds and during regular traffic 25-40 is stumbles and kind of bucks.
Help if you can please, thanks a ton ahead of time.
-Dustin-
Old Jul 11, 2004 | 08:54 PM
1SLOSBC's Avatar
change the plugs!!!!
i just had the same problem.... pretty muched changed out all the electrical.
it was the plugs, after i changed them 2 times already. still has a stumble every now and then, im taking them out soon.
i am no longer a fan of NGK... very bad quality control at the least.
Old Jul 11, 2004 | 10:21 PM
944v8inDFW's Avatar
Did you check the air filter? I had a car once in storage for about a year and it would start fine every couple mounths. Once out of storage it ran like sh**. Turned out my intake tube was being used for a mouse party. Had all kinds of crap in it. Worth a look??
Old Jul 12, 2004 | 02:51 PM
It was a mix of faulty NGK plugs and the Optispark.
Runs like a champ now!
-Dustin-
Old Jul 12, 2004 | 02:58 PM
944v8inDFW's Avatar
Glad to hear you got it going!
Old Jul 12, 2004 | 03:08 PM
Ryan's LT1's Avatar
I was about to say Opti heh. Good job.
Old Jul 12, 2004 | 04:44 PM
1SLOSBC's Avatar
i am going to call NGK and state my complaint....... ive noticed other problems around town and a few other people on messageboards having problems.
guruerror
Dec 12, 2020 06:32 PM
ShwaZedder
Apr 20, 2015 02:31 PM
ShwaZedder
Apr 9, 2015 06:33 AM
97TA-WS6-Con
Feb 1, 2015 01:14 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
