Car Problems
Car Problems
my car is idling fairly high when first started, will keep the rpms 1000+ in gear
and the transmission will not downshift regularly. the rpms will jump back
down once the car comes to a complete stop and is put into park or neutral
and let set for a second.
also I believe this IS related but the car will almost feel like it is having problems shifting sometimes.
btw when the car is in 4th gear around 50mph, accelerating between 2000 and 3000rpm is sluggish and car feels like it's "chugging"
please help
please help
Re: Car Problems
will do, I figured it was something along the lines of tps/maf/map/iac
pretty much guessing it's some how incorrectly metering the air or
compensating and a bad shift occasionally is the corresponding result along
with high idle.
also maf has been descreened for a while
with high idle.
Re: Car Problems
my former car problems that I thought disappeared seemed to have reemerged
ok here's a list of the symptoms
-high idle at intial start
-backfiring when I let off occassionallly
-"chugging" from 2-3k rpm at 50mph in 4th gear(auto)
-no power from a complete stop, accelerates like I'm "rolling" onto the throttle
-occassional high rpm popping which results in a delayed shift
-bad gas mileage
-rich smelling exhaust
I will see if I can arrange to get a datamaster log pulled tonight
-bad gas mileage
