car problems
I have a 97 camaro z28 .....drove the car for 7 months after buying it used and it ran fine....now the car dies when driving it and will not restart......turns over but not start...after sitting the car will start and run again but will eventually do the same thing???????? I have had the fuel pump changed,fuel filter,new computer,new crank sensor,took apart and cleaned throttle body,had TPI sensor tested(tested ok),had computer flash coded....still the problem......any clues to my problem will be GREATLY appreciated!!!!
Main thing would be to check all the ignition components! Spark plugs, wires, ICM, Coil and all of the above. Just check them all out to make sure they are working good! Mainly, Just change out the plugs and wires!
