Car overheated, won't shift out of first!
Old May 19, 2004 | 09:55 PM
  #16
Brent94Z's Avatar
Super Moderator
Originally posted by Bobs 94 TA
It's a clogged cat. GOt a call from the shopt today. The exhaust was backing up and throwing the O2 sensors, thats why it wasn't running right.
I had it replaced in January, so the shop said they'd cover it free of charge. RAWK!
You might also want to have them fix the problem that is CAUSING the cat to clog so rapidly or you'll be right back in there in a few more months
Old May 19, 2004 | 10:02 PM
  #17
GreenDemon's Avatar
One problem on a car can make 3 other ones...
Might want to do some intensive scanning, also your o2s might be a little off if there's enough stuff going through there to destroy the cat.
Old May 20, 2004 | 11:12 AM
  #18
Bobs 94 TA's Avatar
Angry
Son of a bitch.
I got a call back from them today. They said the car is running right(which I allready knew), and something cause carbon to build up in the cat(no ****), and now they're not going to cover it.
I'm picking the car up today after work and just taking the friggin cat off.
Old May 20, 2004 | 11:19 AM
  #19
Bobs 94 TA's Avatar
also, the first shop I had it at removed the O2 sensor, and when I drove it last night, it ran perfectly fine. I guess the exhaust backing up in the ypipe was causeing the O2 sensor to bug out. Thats why it was running like ***.
Old May 21, 2004 | 11:21 AM
  #20
SATANAZ666's Avatar
YOU TOO
Wel it seems im not alone.........
My car doesnt want to go past 2500 rpms on the highway and doesnt want to shift into 4th.......and the exhaust stinks...and sounds different.....did you have these symptoms too?????????? I know i have too much carbon because my tailpipes have black residue on them. can this be my CAT THAT IS CLOGGED...
aNY info or advice BOB is greatly appreciated...
Old May 21, 2004 | 10:25 PM
  #21
Bobs 94 TA's Avatar
Yes, I had the same symtoms. First it sounded alot more muffled, then started to smell inside the car. After that I has all the mechanical problems, so I'd definetly chech you Cat.
97SSdude
Dec 31, 2014 07:43 PM
Cam's maro
Dec 28, 2014 09:30 AM
NewsBot
Dec 3, 2014 12:30 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
