Car now has low idle
I just got everything back on from a head gasket failure.
I adjusted the rocker arms while engine was running, 1/4 turn after "clacking" stopped. The engine seemed to slow down after each time of doing it.
Well, I took it out for a spin, and backing out of the driveway, it's idle is lower than before. Then in drive with no gas, is barely moves.
No surging, engine sounds fine, not rough.
Are the rockers over tightened? Any suggestions?
Thanks.
Thanks.
I did at first, had trouble, maybe it was me. But I asked on this board, and was told the best way was running. Loosen til you hear clack, then tighten until you don't hear it, then 1/4 turn more.
But, I may go back to it. Thanks.
Well, this is literally the first time driving after the fix, and I just drove around the neighborhood. I was going to go easy for a little while, then increase as I go
Its been 2 months since driving it, but seems fine I guess.
But I know I could idle at least a few miles per hour before. Seems like this is an indication that something isn't quite kosher, maybe not.
I didn't touch the TB, except to clean it, which doesn't mean the screw didn't get accidentally get turned if that is possible (just by handling it?) I'll check that out though.
I broke the little black tube (emissions canister purge tube) that goes from the fuel lines, all the way around the intake to something bolted to the intake . Sorry I don't have my manual in front of me. Does it go to IAC? Can't remember.
