car not starting!!
Old Apr 14, 2004 | 09:42 AM
camaroguy94's Avatar
car not starting!!
well i walked out to my car this morning to go to school, put the key in the ignition, turned to the on position, and nothing! everything cut off. like the battery was dead or something. but i had a feeling that wasnt it because it has done this before. so i checked battery connections. and just waited around a while. my dome light came back on and i tried again. this time it started. it ran fine the idle wasnt low or anything. it has done this once before about 4 months ago. could it be a bad ground? if so how do i check? any input is appreciated
Old Apr 14, 2004 | 12:36 PM
TTT
Old Apr 14, 2004 | 12:42 PM
ping0317's Avatar
could be your starter? Are you sure your battery is not dead?
Old Apr 14, 2004 | 12:50 PM
HardcoreRM125's Avatar
You already checked the connectors at the battery, so check all the wires and stuff at the starter solenoid and the ignition switch in the steering column. The starter solenoid oe ignition switch could be bad. I really cant think of anything else though.
its not the battery and its not the starter. everything turns off when the key is turned to the on position before i even try to start it.
Old Apr 14, 2004 | 12:58 PM
My Red 93Z-28's Avatar
Is the security light on in the dash? Just throwing stuff out here
ping0317's Avatar
how is the condition of your chip on your key? That could be the problem too. if you haven't tried use your spare key to start your car
Old Apr 14, 2004 | 01:07 PM
well its like this. i get in, put the key in, everything comes on, turn key to on position and everything shuts off. dome light and everything. then i take key out and everything is still off. you gotta wait around for a little while then lights will come back on. put key back in and either it starts or does the same thing over and over til it decides to start. i dont think it is the starter because i havent turned the key over to try to start it yet when the car cuts off. its just when i turn it to the first position
Old Apr 14, 2004 | 01:09 PM
the chip on my key looks fine i think? how can i check the ignition switch
Old Apr 14, 2004 | 02:34 PM
95lt1&99ls1's Avatar
could be your clutch switch
Old Apr 14, 2004 | 05:17 PM
BUBBA's Avatar
I know you said the battery is "good" and the connections are "good" but: It is imperative that you are "sure" that your battery is "good" and your connections are "good".
If your battery is old or your connections, especially your grounds are not good, then you are just burning daylite by looking for other problems.
With a bad ground, for instance, sometimes the car will start and sometimes it won't. JMHO
Let us know what you find out.:cool
Old Apr 14, 2004 | 07:28 PM
how do i check the ground? i have never dealt with anything electrical on my car
Old Apr 14, 2004 | 07:30 PM
ping0317's Avatar
best bet for you is to purchase a mechnic book about your car. they tell you everything you need to know....Check ebay...
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
