Car not running right....ideas? HELP
Recently my 95 Z hasnt been running right....the idle seems real low and smells rich (stong fuel smell) also seems to be lacking on roll-on power and overall power. car still acts wierd after somewhat long drives on the interstate and bogs WAAAAY down......HEEEEEELP!
Re: Car not running right....ideas? HELP
If you don't have any of those problems, it's time to check some things visually. Start easy and work your way hard. Pull the entire intake elbow off and see if there are any cloggs, voids or tears. You'll be amazed how many stock intake elbows you'll see rolled under at the throttle body. While you're there, check the MAF for contamination from an over oiled K&N and spray with break cleaner(while it's off and completely cold) if it needs cleaning.
car seems to have a "shimmy" while just cuising at about 45ish.....need my 60/65K service done and a tranny flush....think that'll help the overall problem?
1996LT1Z28
Dec 4, 2014 09:20 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
