Car misses at low rpms when warm?
Old Jun 18, 2009 | 01:49 PM
cyteone's Avatar
1994 LT1 it runs great when cold, then when it warms up it starts to stumble at low rpms(below 2500).
It almost feels like its missing at an idle. If I slam the throttle it works great (stumbles a little from the bottom then smooths out).
Anyone know what would cause misses at low rpms when warm?
The Opti, coil, and spark plugs are new.
Old Jun 18, 2009 | 05:13 PM
JooneJune's Avatar
You throwing any codes? (SES light on?)
Old Jun 19, 2009 | 12:19 PM
cyteone's Avatar
The check engine light is not on, and I know it works.
The car runs rich at low rpms when warm or cold, but when its cold it feels like it runs great, it only starts to stutter when warm.
I can smell the unburned hydrocarbons from the exhaust...
Old Jun 21, 2009 | 04:22 PM
94 Assault z28's Avatar
did you recently change your spark plugs or wires or anything along that line i had the same problem. plugs were a bit too loose. try n check.
Old Jun 22, 2009 | 10:45 AM
form94's Avatar
sounds like a vaccum leak. did you check for leaks?
Old Jun 24, 2009 | 09:45 PM
BLKOUTZ28's Avatar
Has this problem been fixed.
Old Jun 25, 2009 | 06:27 PM
tricky69's Avatar
would like to know if anyone has an answer for this, i have the same problem with my 1994 z28. only does it when car is warm never wen its cold.
Old Jun 26, 2009 | 12:03 PM
cyteone's Avatar
I did check for vacuum, it was at 16 in.hg and nice and steady, so no vacuum leak...
I pulled the plugs and they still look new after about 300 miles...
I pulled off the mass air flow connecter, started the car, and let it idle. It didn't seem to make a difference except that the check engine light came on.
Does this mean my MAF is bad?
Or do I actually have to drive the car with the MAF off to see if it makes a difference?
I really wish I could figure this out...
97SSdude
Dec 31, 2014 07:43 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
