Car just up and took a dump
Old Jun 22, 2006 | 01:46 PM
  #16
SEMPER FI's Avatar
Re: Car just up and took a dump
Originally Posted by live4therush
Tried to start it up last night and all it would do was crank over, didnt even try to start this time, all my ignition system is basically new, opti, plugs, wires, coil, ignition module. So its kinda got me stumped, what would happen if the ignition module went bad, would it just kill the car while drivin?
Yes. Like i stated before, it might be the wire that connects to the ICM. It can be shorting your ICM out. Thats what happened to me. I replaced the ICM. And it started, then after a few seconds it died again. So I replaced the wire and put another ICM in and it started just fine. It's been 2 months or so now since I've done this and no problems since. Also I would get a TUNE for your car to turn your fans on at an earlier time. Helps keep the engine cooler, especially now during the summer. Check out PCMforless.com for a tune for your car.
Old Jul 31, 2006 | 05:20 AM
  #17
henryz28's Avatar
Would the ICM cut power to the fuel pump also.Because it sounds like I have the same problem.All the car dose is crank and their is no SES light when the key is turned.I changed the ignition switch and it dident help.1996 z28.
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Alucard
Jul 29, 2002 10:30 PM
