Car just up and took a dump
Old Jun 21, 2006 | 01:30 AM
live4therush's Avatar
Ok so i was drivin down the road and my car just died, when i tried to start it back up, it tries to start and then just diesels a little and dies. I just changed out the IAC, and Bout 5000 miles ago i changed the plugs, wires, ignition module, map sensor, EGR valve, and the opti, so im kinda rulin those out, any ideas?
Car is a 94 Z-28 with an LT1 M6.
Old Jun 21, 2006 | 01:45 AM
stingercamaro's Avatar
Re: Car just up and took a ****
Is it throwing a SES light?
Have you checked for spark at the plug? Fuel pressure?
Old Jun 21, 2006 | 01:47 AM
Heatmaker's Avatar
Advanced Member
have your altinator and battery checked.
Old Jun 21, 2006 | 10:13 AM
radioren's Avatar
Re: Car just up and took a dump
Maybe intake inlet loose hose or open somewhere??
Old Jun 21, 2006 | 10:53 AM
There are no SES lights comin on right now, it just died without warning and then wouldnt start back up.
Old Jun 21, 2006 | 10:59 AM
Heatmaker's Avatar
Advanced Member
WHere was the Thermostate at, and what were you doing at the time in the car, Did you have the radio blasting?
Old Jun 21, 2006 | 11:22 AM
JD311's Avatar
My car did that one day, cut out on me crossing the highway! Anyway mine would crank and just barely run and diesel over. I had just washed the car and had the AI off (hood was not up) any way I unplugged the MAF and it fired up and ran perfect! When I got home I pulled off the AI and a little water had gotten on the MAF. I let it set for an hour and plugged it back in, now it is fine. That was like a week and a 1/2 ago. So.......I would say it could be the MAF.
Old Jun 21, 2006 | 11:43 AM
SEMPER FI's Avatar
That happened to me a couple of months ago. I am almost 100% sure its your ICM (Ignition Control Module). It probably overheated and went to crap. Have it checked they and also check the wire that connects to it. Mine was shorting the ICM out. Hope this helps.
Old Jun 21, 2006 | 12:51 PM
I had washed it earlier but dont think water would have got under the hood, but i'll try it, thanks for the suggestion.
Old Jun 21, 2006 | 12:53 PM
The thermostat was at about 210 bout normal, when it happened tho i could smell anti-freeze so i dont know. And yes i did have the radio up, why?
Old Jun 21, 2006 | 12:55 PM
I just changed out the ICM bout 5000 miles ago, but will check it out to make sure its still good.
Old Jun 21, 2006 | 02:21 PM
SEMPER FI's Avatar
Hmm... If you changed it out then it's most likely not it then. But check it out anyways cause those things seem to overheat.
Old Jun 21, 2006 | 02:47 PM
96LT1TX's Avatar
check the volt meter when you turn key on, ignition off... if it reads under 12 it is your battery, if it reads right at 12, try and crank and see how far it spikes down
Old Jun 21, 2006 | 07:52 PM
Heatmaker's Avatar
Advanced Member
The radio is a big drain on the Battery. If your playing it loud, and your Altinator isn't properly working, it will shut the car off, and make it difficult to start. It may let you sit for a while, but then start back up later.
Old Jun 22, 2006 | 09:53 AM
Tried to start it up last night and all it would do was crank over, didnt even try to start this time, all my ignition system is basically new, opti, plugs, wires, coil, ignition module. So its kinda got me stumped, what would happen if the ignition module went bad, would it just kill the car while drivin?
