Car 'jerks' when gunning it at low rpm
Old Oct 27, 2004 | 07:31 PM
Loading's Avatar
Hi all, I've got a 6 speed, and if I'm cruising around at ~1500-2000 rpm and I gun it in 2nd or higher gear, the car will jerk a couple times then start to go.
If I ease onto the throttle, it'll be fine. If the rpm's are higher, it will not jerk.
Is that normal?
Old Oct 27, 2004 | 10:14 PM
MentalCaseOne's Avatar
Re: Car 'jerks' when gunning it at low rpm
Weak ignition?
Old Oct 27, 2004 | 10:51 PM
jbsupra89t's Avatar
i had same issue... my friend with an 02 ws6 has the same issue. my madz28 tune fixed the "hesitation" in all the gears it would seem. as for what the problem is, i have no idea. i changed a few things including my fuel pump when i was troubleshooting it.
-J
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
