Car Hesitates And Dash Go Crazy At Wot
Old Nov 12, 2005 | 12:12 AM
MENEGRANDE's Avatar
when i got wot the car goes insane, it hesitates and all the gauges go crazy, the needles go crazy and all the lights go off too. as soon as i let go off the gas the car is fine. the engine is knocking too it was not doing so before, please help.
if i go wot in neutral it does not do it, only on a gear does it happen.
thanks
Old Nov 12, 2005 | 05:55 AM
Guest47904's Avatar
Guest
Re: Car Hesitates And Dash Go Crazy At Wot
See if the battery rocks back and forth. Seen some where the battery is loose cause the clamp piece on the overflow resevoir was broke off. Letting the positive terminal of the battery momentarily hit ground.
Old Nov 12, 2005 | 03:12 PM
MENEGRANDE's Avatar
I will try that, i will post results later today!
Old Nov 12, 2005 | 10:31 PM
MENEGRANDE's Avatar
the battery was kind of loose, i retight it, but it still does it.
Old Nov 13, 2005 | 07:12 AM
Guest47904's Avatar
Guest
Check the grounds at the inner right fender and at the ground strap from the engine to the frame. Pull them off, clean them and retighten them. You may have a problem with the engine mounts allowing the engine to torque over and cause a ground problem (among other things). Have someone let the clutch out a little with engine running and the brake held down and see if the engine is lifting up too much on one side.
mr28
Apr 20, 2016 05:44 PM
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
