Car has a miss and I'm stumped
Old May 29, 2007 | 01:11 PM
gas huffer's Avatar
Ok new opti,coil,plugs,wires,icm module,temp sensor,o2's,cleaned maf.
I notice the car has a miss and sometimes even pops, when it is warmer out it runs even worse. i noticed my throttle body was very dirty like black and so were the inside of the hoses. i also tried lookin at the iac valve and it was all the way out. im not sure if it can be pushed in when its not plugged in. the nosal on the map sensor was very black also. so basically im replacing one thing at a time until i find something. any help will be appreciated . thanks
Old May 29, 2007 | 02:33 PM
2000GTP's Avatar
It would be worth a shot to clean out the TB and IAC valve really well with some throttle body cleaner if they are as dirty as you say.
Old May 29, 2007 | 02:43 PM
gas huffer's Avatar
yeah i did but its still doing the same thing.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
