car has a miss...
Old Jun 8, 2004 | 09:26 AM
hawk232's Avatar
car has a miss...
it showed up after i changed the plugs, fuel filter and put in a lt4 km. i assumed it was the wires so i bought new ones and it is still there, so im going put the stock km back in right now to see if that does it. what else could it be?
Old Jun 8, 2004 | 10:12 AM
valter's Avatar
You gapped new plugs correctly? Can you figure out what cylinders are missing? At what RPM's? KM unlikely pull timing that hard to produce miss.
Old Jun 8, 2004 | 10:21 AM
hawk232's Avatar
it is ngk tr55's gapped at .050 i also have datamaster and other diagnostic programs, unfortuantly i have not had the time to learn enough about them to use them to my advantage. if anyone can tell me what i should look at on datamaster i can do that.
edit: it also seems to be mainly at high rpms, say between 3k and redline
Old Jun 8, 2004 | 10:23 AM
Deenasty's Avatar
you sure you didnt get any plug wires confused? Tell us more about the mis, when does it happen (rpm's), when it gets hot? tell us more about it...
Old Jun 8, 2004 | 10:51 AM
hawk232's Avatar
temp doesnt matter, seems to happen mainly between 3k and redline. i doubt that i got any wires confused because i did them one at a time. but i will go back and check. it is weird, it doesnt feel like a normal miss. i have had bad plug wires before and this doesnt feel the same. i dont know how else to describe it though. like i said i have datamaster and all that so if someone can tell me what to look at i will do that
Old Jun 8, 2004 | 11:21 AM
Deenasty's Avatar
when is the last time you replaced the coil or checked the ICM? Also check to see how your o2 sensors are.. Do you have a ses light?
Old Jun 8, 2004 | 12:23 PM
hawk232's Avatar
no ses light, never replaced the coil, and the o2's are reading decent mv's according to datamaster
Old Jun 8, 2004 | 12:52 PM
Deenasty's Avatar
put the stock km back in. Not all km work with all systems. I remember a while back several people were having problems with this. Try that if no luck. replace coil...
Old Jun 8, 2004 | 08:13 PM
hawk232's Avatar
i replaced the km and it seemed worse. im willing to bet that i got ahold of a bad plug. it didnt happen until i replaced the plugs
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
